Headlight Adjustment
tonyianni.ti
Age
58
CA
Canada
2011 Apex XTX
Can someone walk through how you adjust the headlight beam up or down. Manual says 4mm bolt but I'm now sure exactly where to find it. Do you have to remove the entire top hood or can you do it while it is still on and headlight is running? Is clockwise up or down?
Sent from my SM-G950W using Tapatalk
I have not adjusted my Headlight but if you look under the right side grill by the gauge pod you can see the adjustment screw. The hood would stay on.......Manual states
Adjust the headlight using the adjust- ing screw on the backside of the head- light using a 4 mm swivel socket and long extension until correct aim is obtained. Shut the engine off; then disengage the brake lever lock.
Hint... carefully remove plastic grill in front of gauge Pod for easy access to adjustment screw
