DooZ
I think ya had it covered...lolSo this apparatus worked today. I had two redundancies. If the stick broke by my hand it was held in place by the footwell.l, if that broke the strap would have controlled the distance it would have went but still could have slid down the a arm.
slimjim2525
Do you sink the bolt down tight, remove the bolt then set to torque spec. Or, torque set it right from the beginning?
Fords4life
- Dec 7, 2021
- South Dakota
Torque it from the get go, run it short period, then retorque.Do you sink the bolt down tight, remove the bolt then set to torque spec. Or, torque set it right from the beginning?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Cat does it a little different than Yamaha. They torque from the beginning to 51 ft lbs, run the engine and then re-torque one more time at 51 ft. lbs. Easier then Yamaha torque of 108 ft lbs, back off the bolt and torque to 46 ft lbs. or whatever they recommend on that second torque.
stgdz
- Mar 27, 2021
- Buffalo MN
Yeah my biggest fear is rotating that clutch backwards and then it's engine out time.I think ya had it covered...lol
slimjim2525
Yeah, I remember my Yamaha's were like that.Cat does it a little different than Yamaha. They torque from the beginning to 51 ft lbs, run the engine and then re-torque one more time at 51 ft. lbs. Easier then Yamaha torque of 108 ft lbs, back off the bolt and torque to 46 ft lbs. or whatever they recommend on that second torque.
- 8K
