stgdz
- Mar 27, 2021
- Buffalo MN
How do you guys set you headlight hight? The high is essentially useless because it's literally 20 ft ofd the ground but the low is actually pretty good.
I would like to aim it more downward but does that eventually kill how well the low beam works.
Is there a good middle ground or should I just leave it as is?
DennyTuna
- Jan 28, 2017
- Ohio
- 25 Winder LTX LE w/EPS
18 Winder LTX LE W/EPS
97 SX Vmax 600
Set your low beam where you like it as it stays on when you go to high beams. I tend to have my low beam lower making the high more useful. One recommendation I would make is to get rocztoyz headlight adjuster. Easy adjustment on the fly.
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
I second that. I installed the rocztoyz adjuster and it works well especially when you put a load on the back .Set your low beam where you like it as it stays on when you go to high beams. I tend to have my low beam lower making the high more useful. One recommendation I would make is to get rocztoyz headlight adjuster. Easy adjustment on the fly.
blown apex
- Jan 29, 2006
- ALTON ILL.
- ristermotorsports.com
mine was way too high
it was snowing and i couldnt see
4 mm socket gets it
just removed heated storage piece
4 mm socket gets it
