Anyone removed the (3) Heat Shields from an 2004 Warrior to eliminate the rattle when they become loose. If so, have you had any problem heat wise in the tunnel which could possibly really get hot under the seat.
I have removed the rear 1 and will remove the others I havea new MPI exhaust and it is ceramic coated MPI says u can remove ALL the heat shileds for less weight but i dont know if that is gonna work out escpecially the rear muffler 1 My Boss seat sits on the heat shield so i may leave that 1 i am going to talk to MPI before i make finall decision Does anyone else have any info
