1975FA
I finally broke down and got a heated helmet shield. I have read threads on here before about where to wire it into the sled but can't seem to find them now. So where do I tie into a switched, fused power source on my 08 RTX?
radianguy
- Jan 1, 2007
find the blue/white wire near fuse box.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
I’ve always ran mine to the battery with a inline fuse, it comes in handy having power to the shield with out having the sled running...
1975FA
If I hook directly to the battery what size fuse are you using?
WinderFab
- Mar 1, 2009
- Woodbridge, ON
Most heated shields or goggles call for a 3 amp, I’ve used 3, 5 and even a 10 amp fuse without problems...
porkchop
- Aug 19, 2010
- Central NY
- Nytro Nation
Both of mine are just wired to the battery, inline 3 amp fuse.
1975FA
I was checking out a wiring diagram. The blue/white wire feeds the headlights. If I go this route do I need a heavier fuse and how much?
radianguy
- Jan 1, 2007
I powered my temp gauge from the blue white wire but I just put a fuse on that line also. should be fine.
