Exciterfan said:I don't like the idea of changing fuses to a larger size just so I can use the DC accessory. I smell burnt wires....
I'll likely take your advice and run the wires from the battery. But I hate removing the air box on the Vector because of the short vent line that connects to the bottom... Pain in the butt.
But I guess it's the best option.
You shouldn't have to remove the airbox, unless a previous owner moved the jumper/charging cables. They should be in the wide open, clipped to the frame in front of the oil tank.
