Hammer Down
- Oct 7, 2016
- Loudon, NH
- Sidewinder STX-DX 2017
Apex XTX 2012
I have 2017 sidewinder 137 . I am looking for the next heavier size or two torsion spring part# from Yamaha or Cat.
I am 230lb with gear and always ride with the Linq 4 gal gas with luggage bag. I have the BOP 4 slot adjuster and run it on 4. thanks!
Get torsions off a 129" Viper 2014.
Hammer Down
- Oct 7, 2016
- Loudon, NH
Apex XTX 2012
How much stiffer do you think they are? The 129 springs will fit on 137 chassis?
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
I also have a 2017 SW LTX LE 137 . I am looking for a way to re spring my stock sprung springs , back to stock , as they were good for 2 years .
I am 240 lbs. with gear and always ride with the linq 4 gal gas , with a luggage bag , I have the Star 5 slot adjuster and run it on 5. thanks!
Yamaha#8JP-G7474/473 this is the same as AC#1704-576/577 these are what is on a 2014 129" Viper/7000. I would say at least 10% stiffer. I never did find the actual #rating just the specs. Most of us switched to your springs for more sag and softer ride with shock valving.How much stiffer do you think they are? The 129 springs will fit on 137 chassis?
Hammer Down
- Oct 7, 2016
- Loudon, NH
Apex XTX 2012
Thank you I think that should be about right.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I am pretty sure I have some of the stiffer 14 springs. I am not in the shop today. I can also get you the rate info on them.
FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
- YOUTUBE
- FrozenTows1
Cover postage, plus a small tip, and I'll send you a set.
AC# 1704-576
PM me your name & address. Will send out in a week or less.
Paypal when you receive and they work. Tip at your discretion.
AC# 1704-576
Turboflash
- Mar 18, 2019
- Southern MN
On Cat side. it's very difficult to find actual spring rating (in pounds). Usually you have to go by wire size and compare it to what you're replacing. Obviously thicker wire = stiffer spring. I could only find physical dimensions for 1704-576/577.Yamaha#8JP-G7474/473 this is the same as AC#1704-576/577 these are what is on a 2014 129" Viper/7000. I would say at least 10% stiffer. I never did find the actual #rating just the specs. Most of us switched to your springs for more sag and softer ride with shock valving.
1704-576/577 = 0.405" square wire size. 94 deg. angle between long end and short end. 18.5 = length of long end.
Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
- Yamaha powered CAT
I got springs from a Crosstouring 9000 (the 146 long track with extral fuel tank in rear).
Made a world of difference one of the best mods i have done! I now have my adjusters on softest setting. I am 180lbs Its great when carrying luggage and fuel or even 2 up. I think these are heavier than the 2014 options listed above. They were definitely thicker visually.
