Looking for the base weight of the 50/20 2 speeds.
thanks
aj
thanks
aj
I have a set of 50/10s I'd sell
not looking to buy, just want to know the weight of these. the 50/20s I don't have a gram scale..
the kitchen
I believe that those numbers mean 50gr arm and 20gr shoulder total of 70gr but don't quote me. Either way those are heavy you must have a turbo because those won't work stock.
last set i weighed were like about 68ish grams aJ.
They actually act a lot heavier with the pivoting heel tho. You need a lot less mass to achieve rpm,s vs a supertip or heavy hitter style weight.
gothca turk, Thanks Just trying to get a rough Idea of total weight I am using.
at 10 pounds boost on mine i need to run an aditional 5 grams in heel & 3 in tip with white primary spring; 53/43 helix at 60 wrap with a white secondary spring & 144 track with 22/38 gearing. rpm,s are smack on.
My old rx-1 turbo would not pull that clutching at 14 pounds boost.
Right now turk i have the 50-20s with 5 grams in the heel and 5 grams in the tip, White HC primary spring, White secondary spring and Shockwave helix 25/38 gearing but that might change... 144 cobra, 260 picks and till have to test the whole set up out.
I will see where its at, plan on running 12 lbs boost, but I will see.
Last year I was running 91 gram on supertips Green dalton primary, white secondary 60 wrap, shockwave and same gearing on 136 speed track w/320 picks and was still hitting rev limiter. And topping out MPH at the 600-700' marker.
So really I need to start over from scratch with the 2 Speeds and I need to play with gearing as well. I am sure you and I will be talking more soon when we get snow flying!!!
Thanks again
AJ
Thanks again
AJ
