rx-1mountain
hi guys
i have a clutch kit for my rx1 and my weights weigh at 56 grams each with 3.3 grams on the tip and 3.3 grams on the shoulder of the weight. i was wondering is this normal. this is the first clutch kit by heel clicker with the white primary sprng. please let me know!
Turk
Tech Advisor
That is the 40/10,s. The body is 40 grams & 10 for the heel.. You may need another gram heel & tip unless it included another helix & secondary spring.
rx-1mountain
ok...so 40 grams is the weight of the body and 10 grams is the sholder of the weight? then i adds 3.3 grams to the shoulder and 3.3 grams to the tip of the weight. then it will be 56.6 grams in total? is this correct? i have a yellow helix spring with the kit but it says that i dont need to use it becase the stock helix works fine with the kit. let me know if i am right!
thanks
thanks
Turk
Tech Advisor
yepper
rx-1mountain
ok..thank you for the help! i need to order 15.0 mm rollers for my rx1 mtn on wednesday inorder for this kit to work because my 16.5 mm rollers will not work with this kit. what is the engagement rpm with this kit installed? 3600rpm like stock or higher?
