Rayman5271
- Oct 3, 2009
- Northern Maine
- 2016 Yamaha SR Viper XTX SE
Looking for anyone running these HC Drag & Fly weights... hoping to steal someone's working setup/notes for a stock XTX.
Thanks in advance!
Thanks in advance!
Rayman5271
- Oct 3, 2009
- Northern Maine
What do you recommend for a stock machine?I love these weights. I have put them in many sled over a 14 year period--since they came out. However, the 3 cylinder Yamaha will flatten these weights out in about 2500 miles if stock, 1500 with a 190 turbo and my sidewinder ate a set in @600 miles
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I"ll have to look at my notes. I also use set screws purchased at the hardware store for more precise measurements. Do you have a gram scale?
The weight is set up as follows for a Nytro XTX,--shoulder 1 silver bolt and 2washer, base end- 1 bolt 1washer and OD 1 bolt 1 washer. you may need to install a set screw in the tip if it over revs on top.
Black HC spring. Stock helix
