MarkRTX
Who has used these two setups and which one performs the best gonna test both tomorrow with the 2 speeds against my best D&F setup. Just moving the sled around the house the 2 speeds engage smoother in my opinion more so than the D&F weights but we shall see tomorrow on ice once I dial in the 2 Speeds will run 660 1000 and half mile. Last year on ice I got 117 gps before my PC3 and ing module so we shall see. Welcome to all comments good and bad Thanks Mark No friggin snow to really ride on up here in Maine.
yamahahaapex
Cant wait to see how it goes for you, Im getting the 2 stage set when my beast finally breaks in
Turk
Tech Advisor
Used em both. Nothing grabs the belt down low like the 2 speeds.
drag n flies work well too but i do get a little more from the 2 speeds.
MarkRTX
And a BIG THANKS to you Turk with all your help with my D&F weights last year and your help with a setup to start with. Its great guys like you that help us newbies to clutching. I know much more because of Turk and others on this site and a big thanks to all. I also nesides the PC3 and ing module added studs up to 162 because of traction issues for me. I also just recently got the 911 billet cover for the primary but I'll tell you everything the bushing and putting the bely adjuster on its very very tight that may be good but when I have to pound the socket on with a rubber mallet to tighten the primary bolt I started to have some reservations so took it off for now and will talk to the guys at thunderproducts on Monday
