Mad Russian
Just wondering if anyone tried the drag n flys or 2 speeds, and what would work better. If anyone have any setups that work please speak your mind. I had the drag n flys on my attak and i loved it. But would like to try the 2 speeds for some extra top end speed. Thank you for any info.
Turk
Tech Advisor
i am using 2 speeds on my xtx but with a yamacharger so it won,t be the same.
Start with black hc spring; load the heel then add inner weight if needed for a good starting point.
yamahahaapex
2 speeds man, i had heelclickers on my attak set and i loved them but i got 2 speeds on my '11 and its like awakening the beast within. Well worth the cash, I am completely satisfied with my kit. Ive had other kits I have bolted in and by far this one kicks a$$
yamahahaapex
bolt them in and hang on, pulls way way harder then than what i had in the attak and now youve got traction, well you know the outcome. youll be hard to beat
Mad Russian
2 speeds it is. thank you for the info.
Daranello
Suspended
Good top end with 2speed?
yamahahaapex
seen a good top end increase of 10-15kmhs compared to stock weights, cant compare the clickers to 2 speeds though due to the obvious circumstances
larrypolaris
How do the 2speeds work on the Nytro's.
Not much talk on that site about 2speeds. Mostly Dragonfly's and Ulmers.
Turk
Tech Advisor
I have a good set up with 2 speeds in a nytro. I used em in my xtx.
