phaze5
whos got them how much and where
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
try www.oregonscientific.com self contained unit. Wish I had gone this route last year instead of the camcorder and gear.
phaze5
thankscc47 out of stock is it a recorder also
mxbulldog
Just bought the oregon scientific camera off of ebay. will put up a report when I receive it and get a little saddle time with it.
Crewchief47
- Jan 16, 2006
My understnding is that it records to it's own built-in memory (32Meg???) or optional SD card up to 2Gb, but you'll have to look a little closer at the webpage. It has a higher res than the Mini DV camcorder I bought as well. We'll have to wait and see what mxbulldog says about how well his works.
tonymanto
i've bought a couple of the Oregon Scientific helmet cams. they're worth the money if you're shooting in the middle of the day and it's warm out. it's seems once the sun starts to lower to the horizon, anytime you face that direction, the picture totally washes out..... also, when using in cold temps, the camera maybe will stay on for ten minutes. after that you have to warm it up and take the batteries out until warm again. i heard lithium batteries make a big difference though. overall, for the money it does the job, most of the time. if you're looking for a higher quality picture that consistently works in all temps, then you may want to spend the extra money..... oh, also, i can get a hour of high resolution/lower compression (VGA) out of a 2GB flash card.... ebay seems to have the best prices on these. try to find a bundle package with the card included. ends up being cheaper.
phaze5
how much do you figure you have into it
mxbulldog
It was $100 on ebay, plus shipping.
YamaChris
tonymanto said:i've bought a couple of the Oregon Scientific helmet cams. they're worth the money if you're shooting in the middle of the day and it's warm out. it's seems once the sun starts to lower to the horizon, anytime you face that direction, the picture totally washes out..... also, when using in cold temps, the camera maybe will stay on for ten minutes. after that you have to warm it up and take the batteries out until warm again. i heard lithium batteries make a big difference though. overall, for the money it does the job, most of the time. if you're looking for a higher quality picture that consistently works in all temps, then you may want to spend the extra money..... oh, also, i can get a hour of high resolution/lower compression (VGA) out of a 2GB flash card.... ebay seems to have the best prices on these. try to find a bundle package with the card included. ends up being cheaper.
Is this with the cold weather case?
