Pykie
Hey Guys,
Hopefully one of you can help with this. I changed the track this off season and was maticulous with order of parts and pictures. Put it all back and followed the directions, or so I thought. I could swear it had reverse the first time I ran it and tested it all. It is currently set to the 27mm spec for the top rod and i believe has no free play on the side rod. I can shift freely from fwd to reverse and it does beep.
Is it possible that the linkage still needs an adjustment or is it more likely that I goofed something up inside the case? There are no weird noises, sled ran great all weekend long with the exception of this. I don't want to go to the bother or removing the whole lot again if it just needs an adjustment.
Thanks in advance.
Thanks in advance.
