apexgt4life
I was in hte process of changing gear when wrench slipped and broke of the chain tension post what do i do
LazyBastard
Well, the first thing that you do NOT do is go buy another one. You have two choices here;
1) rig something up with bolts and washers,
2) get it welded.
For (1), I would get a piece of aluminum bar that fits perfectly between the chaincase back and the chaincase front (od that matches the inside of the tensioner), drill/tap both sides, and bolt it in from both sides. I recommend (2).
2) get it welded.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
yep thats a good fix....
I know many racers who do this MOD when new....the stock tensioner post is a crappy/poor design and tapping a hole in front side makes it much stronger...
Id do exactly what was stated above...or you will be buying a new case.
Dan
Dan
apexgt4life
yea i freaked out and ordered an new one but might cancell order it was 150 bucks, can that be welded what is it aluminum or what
LazyBastard
Its aluminum. Only the cover is magnesium.
apexgt4life
ok u think a weld is a good fix i dont want this thing breaking down the trail
LazyBastard
You could even combine #1 and #2. Weld the post back on, make a shim to fill the gap between the end of the post and the front of the chaincase, drill, tap, and bolt. Do that and it'll NEVER come apart.
ReX
LazyBastard said:Its aluminum. Only the cover is magnesium.
If I recall correctly the 06 and up chaincase is all magnesium.
The 05 RX-1 without reverse was the only sled to get a magnesium cover on an aluminum case.
Many people assume magnesium can't be welded, but it actually welds similarly to Aluminum (as long as there are no sharp edges to catch on fire...). Some welders also use an inert atmosphere when working with magnesium, especially if they are preheating the parts.
(BTW, I am far from an expert at welding...)
Austlor
- Jan 5, 2014
- DeForest, WI, USA
- yes
Is this still the preferred way? hopefully something has changed in 13 years?
