HELP Clutch side BEARING question!!
RacinJason15
Comstock Park, MI
17' Yamaha Sidewinder LTX DX
LOCATION
Comstock Park
i just installed a new clutch side bearing in the upper bulkhead and i saw in the microfiche that there is a washer that i cant tell where it goes! it is number 17 on the secondary sheave section. when i took the jackshaft apart i saw no washer that was behind the lock nut on the sleeve.... is there an update that you need to be putting the washer behind the nut? i have the new two recessed washer and the regular washer on the outside of the bearing that the secondary clutch mates to when you put he secondary on, but i am wondering this cuz i ordered the washer and then put it together with the sticky thread on jackshaft install and it showed no washer... anyone had this washer and is it something new?? any help would i would be greatfull
Jason
I've never seen that washer before! Just bearing taper collar and lock ring. There are 2 washers that go between the bearing and secondary clutch. Are you saying you have this washer left over or you ordered it because of the diagram?
I ordered from diagram and didnt know if it was an update........
