Boy was riding his 2007 Phazer MTX today and had a large stick go thru the A arms, past the plastic cover, and into the engine bay. Tried to start it but it had engine codes 14 and 26. Brought it home and pulled the front air box cover, all side panels off and had a look inside. The stick had hit under the air box so hard it pulled the rubber intake manifolds right off both cylinders. You can visually see the inlets and the rubber mounts are disconnected. I looked thru manuals and took a quick search on the internet to see how to get low enough in the engine bay to get these re-coupled. Does any one know of a video or manual that will explain how to get low enough in the engine bay in order to connect these back together??
