I take it you got your hood. Hope your happy with it, it was primo shape.
Nothing hooked up from kit, including intercooler. What is flooding it is when you plug in the MCX box it makes the TPS sensor non variable and sits at 53, essentially half thottle, and doesn't move with thottle position. When you unplug the box it works exactly how it should, 15 at idle an 95 wide open.
I think the wiring harness from Randy might not be the right one. He gets lot of proto stuff and this harness was never installed with this box. I called PG and asked for a pin diagram of the harness. I'm sure that the pins are not in the same order in the plug that they should be. Pretty much all it can be now that I know how it is flooding.
The box was put into the owners sled at PG so I know it is good, as well as a new baro sensor.
Are you near your sled? Can you check the pin.....hell, I'll just call.
