HELP! I Need Measurements on shaft for Wahl Extroverts
Traverse City MI.
06 Apex ER
I am in the process of pressing a set of Wahl Extroverts on my driveshaft. Can anyone give me the measurements as to where exactly they need to go on the shaft. Any help would be greatly appreciated.
Thanks, but I am putting on the drivers that go through the holes in the track that Wahl Racing sells. I have already removed the four stock drivers and now I am just putting two back on. It would be great if I could get a sketch like this with the Wahl sprockets on the shaft.
Any help would be great!
You need to mark a center line on the shaft between the stock drivers before you pull them. If you didn't...I can't help. If you did...it's simple math. half the center on center measurement of the windows minus half the width of the driver gives you the distance to press them to relative to center. I put mine out board another 1/16th of an inch so they ride on the outer side of the windows and my track doesn't walk.
I think I worded this right.
