yamadog07
can anyone confirm if rails need to be trimmed if i add wahl brothers extroverts ?
there is talk of "anti stab" wheel kits.
are these required on the 136 attak skid when extroverts are installed ?
ahicks
If all you are doing is installing the extro's, you'd be the first I know of if you had a problem. Familiar with the issue. I had to do my conversion. As far as antistab kit, you shouldn't need it - unless you are messing with the stock skid location?
yamadog07
nope, no changes. reason i ask is wahl bros advised i may have to do this because it's a 136" skid. i had not read about anybody else having issues.
just want to do it right the first time.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
No changes, we have installed 9T - 2.52" pitch Whalbros extros for years in the Apex'es and Attak's without any problem of drivers hitting anything.
You may mix it up with the problem running Whals on RX-1 and Warrior, the ProAction skid cross shaft did not leave enough room for the outside teeths of the drivers, we had to grind them down until the no longer hit.
