Help im stranded!! error code 33 09 nytro
Corey9965
Central Wi
I'm stranded on the side of the trail with my 09 nytro rtx with code 33. I called Hauck and they said its an open circuit on cylinder 1. Any help would be great.
Also, check spark plugs and wires for rubbing, wear through.
Maybe unplug/plug ecu
Swap the ignition coils around to see if it changes to a 34 or 35 code
is the wire harness rubbed through just behind the primary clutch ??
did u find the problem ,not mine is doing this ?? :o|
