srxr700
- Feb 8, 2012
- cedar springs michigan
- 2006 Attack
2012 Vector
Working on 2012 rtx that doesnt have low beams. High beams work and the bulbs are good. Does anyone know where to start?
Stock lights? Have you check the switch? or continuity when you unplug the switch.
srxr700
- Feb 8, 2012
- 2006 Attack
2012 Vector
Stock lights. I have 0 continuity on low...
sounds like the switch is crap. Can you pull it apart and check to see if its all corroded?
srxr700
- Feb 8, 2012
- 2006 Attack
2012 Vector
The sled was rolled and the hi/low button was broke off. It must be a bad switch.
srxr700
- Feb 8, 2012
- 2006 Attack
2012 Vector
Well i installed a good used switch and still no low beams..
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Check the headlight relay. It could be borked. And also the obvious, the fuse.
I agree..
srxr700
- Feb 8, 2012
- 2006 Attack
2012 Vector
Where is located? Looks like it's behind the resevoir?
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
All the relays are behind the ECU It's different than the others because it has 5 wires Another one with 5 wires is the reverse relay. I don't know which position it's in.
srxr700
- Feb 8, 2012
- 2006 Attack
2012 Vector
Thanks Mooseman..It was indeed a bad relay.
