blown apex
- Jan 29, 2006
- ALTON ILL.
- ristermotorsports.com
installed 2 sets of wisco piston/rings
one set last year 1 qt every 100 miles
2200 miles
with 2 % 7 % 7 % 2% leak down
installed 2nd set and same 1qt in every 100 miles
will do leak down on 2nd set tonight
i use yamaha 0 30 oil
are the rings just not breaking in due to
yamaha oil
before i tear this down again any suggestions helpfull
thanks
duane
618-781-4703 or post
2200 miles
yamaha oil
thanks
duane
Travis Moore
Sounds like a problem with the oil control rings? Too low tension?
T
T
blown apex said:installed 2 sets of wisco piston/rings
2200 miles
yamaha oil
thanks
duane
Did you send the block out for diamond honing before you put the low comp. pistons in?
TWIN TURBO
- Aug 30, 2005
- Chicago IL.
- www.powerbygns.com
I use Mobile 1 5w40 on all turbo and supecharged applications and yes I have diamond honing equipment a must with every new ring install. Have next to no oil consumption. Can hone yours if you you need
blown apex
- Jan 29, 2006
- ALTON ILL.
yes i had millenium re hone cyls and open up to
.003 piston to cyl clearance
rings file fitted to .017
did leak down last night
all 8% i had 2% the 1st time
- 6K
