HELP PLEASE !! I am having trouble 2003 RX-1 (10 PSI Asphalt
Way cool - you're making progress each time out, keep up the good work.
Looks like you are making a good showing now!
RX1DERFULL said:
Latest update.
9.52@136.0 1.39 60'
Nice, are you still running 10lbs. psi? What setup do you have now for clutching and gearing? Skid?
Yep,
Still running 10 PSI S/C by MPI.
10 tooth drivers
24 - 38 gears (just barely running out at 136 MPH).
Custom skid (my own design using some Whal parts.
I am using the stock front spring and heavy hitters with custom copper inserts in the heel, but I am still having some belt slip issues off the start line. I think supertips may help this (not sure?)
Ulmer stage one helix with a Yamaha white spring.
One change for this year was a narrow track 10 5/8 X 121"
I welcome all questions
