Help..small hole in front heat exchanger
Heritage
Northern Wisconsin
Looks like a stud got it...a small stud sized hole.
I limped her home..about 5 miles...stopping twice to
let her cool...she was pretty hot..hope I didnt do any
Engine damage.
My question is, can I patch it with that jb weld putty, container says
It works on aluminun..never used stuff before..only have the one
small hole...otherwise exchanger looks good. Any tricks to adding coolant??
better do a search,lots of info on this 1,tig or mig weld is a must,no jb weld,recipe for disaster even if some tell you that jb weld works,its just a band aid on a serious wound
Could of not said it better.
I have had great success with JB weld.
This is not a temporary fix. I have put a total of 11000 miles on the sled and more than 7000 miles and many years since the fix and it looks like the day I did it.
We cleaned the area and then roughed up the surface to really bond. I also repaired an aluminum oil cooler radiator for a john deere tractor also lasting for years.
I know I will not hesitate to use it again........prep is everything.
My two cents
Yamadoo
Thanks for the replies guys...i am gonna try the jb weld
I dont have a heated garage, and am not a good mechanic,
which was the main reason I bought a yamaha
:o|
She was running awesome today...i dont miss my old crossfire
at all..love this sled. I know I will never have the skill to get that
front exchanger out...that looks like a major job...unfortunately
I dont have the cash right now to take it to a repair shop.
Total bummer, the trails were great today
:o|
Shame......you will need heated area for JB weld. Did you talk to Kip or Chad? I would not tackle either. We ride not wrench.:)
You are welcome to use my lift just come get it & return when done if you change your mind.
