John Bjorklof
- Jun 28, 2015
- finland
- Other
- Phazer 07
It's driven only 8500 km so it should not be that
Surestick
- Jan 19, 2015
- '07 Phazer Mountain Lite
Is the TORS light coming on?
Have you checked what the intake air temperature is reading and also the coolant temp sensor? This can be done through the dash. I had an 06 apex last year that didn't want to start, and the coolant sensor was sending a higher reading than it should have been. However, no error code was showing.
John Bjorklof
- Jun 28, 2015
- finland
- Other
- Phazer 07
what light is that? it is giving me no errors codeIs the TORS light coming on?
John Bjorklof
- Jun 28, 2015
- finland
- Other
- Phazer 07
how to I do that?Have you checked what the intake air temperature is reading and also the coolant temp sensor? This can be done through the dash. I had an 06 apex last year that didn't want to start, and the coolant sensor was sending a higher reading than it should have been. However, no error code was showing.
YukonMP
- Dec 25, 2014
- Yukon Territory
I have to go out the door right now but what 74Nitro is referring to is putting the ECU into diagnosis mode. By some combination of otherwise unlikely button pushes/holds the ECU display a number of attributes, one at a time. Do a search and see what you can find.
Regards TORS, my guess is that your model has no light but throws a code. Good luck.
DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
https://ty4stroke.com/threads/diagnostic-mode.139840/
Same gauge package . Maybe it will help
https://www.manualslib.com/manual/660081/Yamaha-Pz50w.html?page=22#manual
This might give you the whole Manual
Surestick
- Jan 19, 2015
I thought there was a light or indication on the gauge pod? I'd have to check my manual which I don't have with me at work
YukonMP
- Dec 25, 2014
- Yukon Territory
Nice DGZRT. I have the 2014 MP/Phazer manual and there are no significant differences. Don't forgot the NOTE on the end of the first page, that you have to restart the process right from the beginning each time.
You are right Surestick ... code 84 on the guage pod.
Let us know if you can't figure out how to bring this up.
I just love how all the components can be checked through the machine without any external hook ups unlike some brands.
To my knowledge, these codes apply across all Yamaha product lines.
YukonMP
- Dec 25, 2014
- Yukon Territory
The next time I have some spare time I want to mess with this. Previously I have been reluctant to try lest I turn on the computor and can't get my sled back to normal but as I read it that is not really likely. I'm not nearly as intimidated by this machine as I once was .... thanks to TYers.
Yukon, I have the 2006 technical update book, so I have info on many codes etc. Don't hesitate to ask.The next time I have some spare time I want to mess with this. Previously I have been reluctant to try lest I turn on the computor and can't get my sled back to normal but as I read it that is not really likely. I'm not nearly as intimidated by this machine as I once was .... thanks to TYers.
YukonMP
- Dec 25, 2014
- Yukon Territory
Thanks 74Nitro. Lets hope John in Finland finds some joy in this too.
Shaune
- Oct 21, 2015
- Halifax
- 2008 Yamaha Phazer GT
Following. I have an 07 Phazer and having sorta same issue. Although mine will fire up perfect for about 10 seconds and then shut off. Fire up again and then you can crank it over endlessly and wont fire up again.
YukonMP
- Dec 25, 2014
- Yukon Territory
Sit tight until a few guys chime in, repeated 10sec runs are just going to end up fouling the plugs. You might even start another thread with all of your details, it makes it easier for guys to keep straight as your issue might be something else.
