I can not find the light green wire to ground out on a 07 atak. I looked all along the main wire harness on the pto side of the delta box.
Is it down by the ecu?
FLYBYU
just follow the wires from your throttle position sensor and you'll find it
Thanks for the reply,
I still can not find it.
Close to the TPS there are 3 plugs that are not hooked up but no green wire.
Is the green wire have its own connector with no other wires running with it?
FLYBYU
http://www.ulmerracing.com/Stealth.pdf
Thats what it should look like
Thanks a ton
It is a white and green wire for some reason. The pic helped
I never thought I would get help so fast at 2:00 am FLYBYU.
Gee and I had a post on Air/Fuel in which I was told to adjust the CO Trim, and was waiting for one of the guys here to send me a fax on it or Jim from BPE to step me thru it, and here it is, Thanks.
TBird
- Dec 25, 2004
- North of Sweden
- Sweden
- Yamaha Viper and Yamaha Nypex
And it´s never been posted before http://www.ty4stroke.com/viewtopic.php?t=66704hlmrx1 said:Gee and I had a post on Air/Fuel in which I was told to adjust the CO Trim, and was waiting for one of the guys here to send me a fax on it or Jim from BPE to step me thru it, and here it is, Thanks.
FLYBYU
no problem. tbird had found it for me also
