overkill131313
- Mar 12, 2010
sled is a 06 Apex MCX turbo kit but dont think that is important!
I have a code 20 and it is blowing a fuse by the starter solenoid......any one help me? I have to figure out what this fuse is for but when it blows the fuel pump stops! I can cycle the fuel pump for 5 mins buy turning the key on and off for 5 mins.....fuse stays good.....if I start sled it will run for 20 seconds then blow the fuse. WTF!
code 20 is: 20 Intake air pressure
Atmospheric pressure Defective values are detected due to the internal malfunction Fixes the intake air pressure and atmospheric pressure to 85.0 kPa. Able Able
every sevice manual that I have found is different than what I need....I need to find out what the two fuses on the solenoid are for.....the manual shows one main (30 amp) and that is it.....I have that one plus 2 10 amp fuses on each side......one of these is the one that keeps blowing!
HELP!
HELP!
overkill131313
- Mar 12, 2010
doesnt seem to be blowing fuse any more but cant get rid of the code 20!
