Which models have a split throttle block that can be installed on hooked bars? I think pretty much all of the 4-strokes but can't really tell for sure. After some time searching the parts catalog and looking at sleds I think I will just ask.
I am retrofitting hooked bars on a Viper so will obviously have to rewire the plugs. But as long as I use the 1 into 2 throttle cable (2004 and newer Vipers) I am hoping I can retrofit the throttle block.
I think I need one with thumb warmer, kill switch, and TORS switch and I should be good to go. Don't need the rocker switch for thumb warmer, etc. but it wouldn't hurt anything not hooked up. How about the 2007 and newer Phazer throttle block? Would that be a good option?
Has anyone ever measured the throttle pull distance on these blocks (how far the cable pulls)?
