Red2003
Hi guys,
I've searched through all the posts on this topic and don't see anything recent about NOS. The kits look to be between $600.00 and $700.00 total. Thats not bad for 35 - 60 + HP. My questions are these. Has this been a reliable mod, and in my mind this would be all a guy would need to mop up those few remaining sleds we can't smoke with these beasts, right? I would use it maybe half a dozen times on the lake throughout the winter, and forget about it the rest of the time. So I guess I'd like to hear from you guys who have run it for awhile, and if you've seen any negative results like popped engines. If it's all good, why shouldn't I do this. Looks like a great way to get to 200 HP without a $4000.00 turbo. Talk to me guys!! Thanks!
I moved this to the Nitrous section. Your much more likely to get help here...BBY
yamahajunkie
$300 in nitrous all season 70 sum#s. 3100+ mile no grief, except that cpr rx1. now have bigger shot. wont know til next if its big enough. as far as only using it a 1/2 a dozen times a year :ORC. trust me you will drain the first couple of bottles with the quickness. ya gotta clutch it.... right
- Apr 14, 2003
- Hessel, Michigan
red2003 - I had a 2003 RX1 with 48 horse kit on it. Used it on asphalt, (Racing thread - 2003,2004 results in this forum), and I love the way the RX1 works with it. I currently am using on asphalt on my 2005 RX1, and also used it all winter. I put on 4,400 miles this year, and went thru 20lbs. of nitrous. My system on the 2005 is Holtzman's 60 horse. Boy does it fly!
yamahajunkie
nos pro you only went through 3-4 bottles in 4400 miles? that sounds kinda low. not using it that much?
jtssrx
with a 2.5 pound bottle he would have used 8 bottles.
For the most part NOSPRO is a trail rider. He's not out on the lake every week end racing so I believe him
Rx1M5
I heard through a dealer that Holtzman is coming out with a new system. Anybody else hear this?
- Apr 14, 2003
- Hessel, Michigan
Holtzman is working on something new, and I was there when he told me he was getting the patent on it. Don't ask me, cause I don't even know the just of it. Barry is a super engineer, and finds things that most of us wouldn't even think of. Just that the new system won't use as much nitrous, and will produce the same horsepower.
KbxSrx
Its no huge secret, he is going to a dry system now.
what about nos on a srx? is it still reliable or what? thanks!!!
yamahajunkie
tried my on my 98 srx worked like a charm. didnt have time to dial the clutching on it out of the hole, but what a blast on the topend!!! tried the same kit on my raptor, to big of a shot!!! it about gave it a heart attack. you can put these kits on anything within reason. junkie
- Apr 14, 2003
- Hessel, Michigan
Junkie - You hit that one on the head.
looking4speed
I used it this winter.I used a Nitrous express kit at 36 horse it worked great no problems.I also tried a NOS kit on a raptor at 25 horse.You cant ride it without going over backwards,guess it will get an extended swingarm then lookout at the dunes.
yamahajunkie
got a new ignition for the raptor, custom curve and rev limiter. its fun having a 90 horse quad on the bottle!!! makes the trails narrow up a bit. not quite a sled though. keeps me sain though
