MarkRTX
I ran my sled with this setup really for the first time today while testing clutching. Heres what happen after letting off after a 1/4 mile or so run the sled would almost stall or did but came right back to life headlight out and everything? Any ideas where to look for the problem? Ground wire? Anyone else ever have this happen also stalled while turning around in the boat landing area and while loading onto trailer and then wouldn't stay running had to use the throttle to keep it running Ideas?? The only other thing I can think of is before I had the PC3 I had my ram air lid and adjusted the low end fuel on the pod to I think plus 10 or so and can't remember if I set it back to 0 before I added the PC3 and module. Please help with any ideas Thanks
MarkRTX
TTT
bobber
Are the two units plugged together?
MarkRTX
Yes they are ???
MarkRTX
Yes they are ??? will check all connections tomorrow just to make sure from begining to end
yamahahaapex
unplug unit by taking the main ecu cord from pc3 box and plugging it back into stock plug in, basically bypassing everything, take it out for a rip and see what its like stock
MarkRTX
Thats the plug right on the frame by your clutch right?? I also will ground the pc3 and ing module to the same bolt to check that too Thanks
yamahahaapex
yes the plug on your frame
