zimmer said:I read if you buy the rsi hand warmers you can use the stock wires going to the switch all you need to do is join two wires from the warmers together and connect to the existing wire goin to the switch and the other wire from the warmer to the other wire goin to the switch, has anyone done this and have you had any problems any info would help
