SHodas
yam177
Its a Spacer for the upper gear bearing You need to to support the jacksaft and the inner race of the bearing
Grimm
Use the microfiches here to give yourself a better idea on how it's all put back together.
http://www.yamaha-motor.com/sport/parts/home.aspx
SHodas
Not for the upper gear, that collar is larger in diameter. I tried the microfishes, not helping. the ony place it fits is on the jack shaft after the nut goes on, based pn that diameter, thanks
