woodlawn
Hi,
I have an 04 RX-1 that during the last ride of the year last season used a couple more litres of fuel than usual. I didn't think much of it and planned on cleaning the carbs in the off season.
i cleaned the carbs(they were spotless) still tooked all apart and went over them completely while i had them out. i cleaned the coils and use dialect grease as well.
Machine starts, idles perfectly. once it hits 6000rpm it has a hesitation and works through it quickly if you open the throttle. once driving the hesitatin stays if you are in the 6000-8000rpm range if you open the throttle it runs fine until it returns to 6-8000rpm. It doesnt back fire or idle poorly, it engages fine and runs perfect till 6000rpm. Also no hesitation if held wide open off the line. It feels like a timming issue but there are no codes showing for a bad TPS sensor. The plugs are all burning as they should be.
Went for one ride this year and ran seafoam in the tank as well. Sled used a couple more litres than it is supposed to again.
Any ideas?
Any ideas?
