HH Weights
sdracer
Rapid City, South Dakota
I would like to know the total amount of weight that you are running with your HH weights? Whether you have a 48 gram or 60 gram weight, I would like to know the total weight of your HH weight for the rx-1. Appreicate any help.
I used to run around 64.5 grams. But it varies depending on springs and helixes.
61.6 total grams... 1/4 + 3/4 in the heel, 7/16ths and thick washer in the middle, 3/8ths steel with thin washer in the tip. Silver secondary wrapped to 90 degrees. ECP filter kit...... Hang on :shock:
It will vary depending on studs, rider weight etc. Give Matt a shout at the speedshop, I know he has done many hours of testing. He helped me with the setup for my Warrior. I also have the ECP kit with a bender exaust and am studded and am very eager to try his recommendations next season.
Thanks guys, this will give me a base line were to start. I ordered a new 05 rx1 er and I'm coming off of a htg-1000 xcr Polaris. Thought I'd like to try a 4 stroke this season.
