woody69
Took my mcx turbo apex 310 out for the first ride today
Runs real strong ,but is it normal to see your boost gauge reach 25 lbs ?
Turn down the turbo smart ,got her around 12 lbs after
givemeaboost
- Dec 5, 2003
- Great Falls, MT.
- 03 Rx1 Turbo
- Great Falls,MT
I hope that you were running straight race fuel in it when it hit that high of boost. All it takes is 3-4 seconds to start the detonation meltdown problems when you don't have enough octane.
Ken........
Ken........
woody69
50/50 mix 92/108
But I only pinned her long enough to see the gauge hit 25lbs
I tought the most the 310 kit could produce was 17 lbs ??
ghost rider
Suspended
- Nov 13, 2013
- Muskoka, Ontario, Canada
- Rxwarrior
- Muskoka , Ontario
woody69 said:50/50 mix 92/108
Is your motor stock or modified?
woody69
Motor has a shim and timing cam changed
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
All it takes is a iced or pinched pressure line between the compressor housing and the wastegate actuator bell. No pressure to the bell and Your turbo will make maxximum boost which is around 25 lbs.
To make sure you did not suffer ring damage; a compression test is called for.
