joel
- Nov 12, 2006
PUT A EXTREME SD CLUTCH ON MY 06 GRIZZ 660. NOT REALLY INPRESSED WONDERING IF THERE IS A BREAK IN TIME OR SOMETHING SMALL I MISSED. SEEMS TO BOG MOTOR FROM THE GIT GO. STOCK SEEMED TO HAVE MORE LOW END . ONCE UR GOING ITS PRETTY SICK I HAVE 27 INCH MUDLITE XTR ON THE ITP 14 INCH WHEELS, GOT IN SOME MUD SO THICK IT WOULDNT EVEN TURN THE WHEELS SO I GOT THE CLUTCH KIT FOR THE LOW END BOOST BUT ITS NOT THERE,,,, ANY THOUGHTS?
most of them suck.... try taking a cutting 1" off your carb spring, that will wake that low end up some...
Another thing that help is the wet clutch springs.
joel
- Nov 12, 2006
THOUGH IF DOING THAT.WANNA BUY A NEW SPRING INCASE IS MAKES THINGS WORSE. IT JUST SEEMED THAT STOCK HAD MORE LOW END LIKE WHEELIE KINDA LOW END. DO U KNOW IF THE SPRINGS IN THE WET CLUTCH ARE SOFTER OR STRONGER THAN STOCK.
stock wet clutch springs are softer then the big wheel kit springs, it suppose to allow the motor to rev more.
joel
- Nov 12, 2006
THANKS FOR THE INFO. I GUESSING THE SECCONDARY IS HARDER AND WEIGHTS LIGHTER?
I JUST TOOK IT A PART A BIT AGO AND TOOK SOME CLEANER AND SAND PAPER TO THE SCHIVES. LIL RIDE SEEMS A LIL BIT QUICKER TO INGAGE, THINK I HAD SOME OIL AND GREASE FILM ON THEM FROM INSTAL.
I would think less weight in th primary would allow it to rev more.
