Mtn-Track
Did some searching but haven't really found anything about it.....
My 07 Vector has a high and low idle that seems to work on a cold start. But once it's warmed up it drops from a high idle to a low idle after about 5 seconds, then quits. If I adjust the idle up a little, it stays on high idle, which I think is too high. I can't seem to get the sweet spot in the middle and it's really getting anoying!
Anybody else have this issue? What am I missing here?
Dealer hasen't been any help on this one.........
My 06 Vector Mtn SE does the same thing. I think it is normal.
I don't know much about the three banger, but cleaning out all jets and float bowls, check O-rings, and sync the carbs would be a good start if you can't get it to idle correctly.
LoneViper
My Vector had a very fine line between high and low idle. I just let it idle at about 2000 and it would eventually come down. I sort of liked it as it would reduce engine braking.
Mtn-Track
Thank's for the replies guy's! I guess I'll adjust it so it stays on high idle. Every time I stop, after about 5-10 seconds it still drops to low idle then stalls out. Carbs have been gone through several times and it didn't make any difference.
GUKROKIT
I had the same problem on a 05 vector.If I remember correctly the pilot jets were fixed.I would try installing the next size richer pilot jet.The richer mixture should lower the rpm at idle.hope this helps...
