Fleecer
- Jun 13, 2014
- 2019 SRX
My bad grabbed the wrong box, that pump # was for my 07 mustang gt, this Deatschwerks # is what i used with 300hp header tune #9-201-1000
I just ordered one, as they offer a 3 year no fault warranty. Thanks for the info!!
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
Walbro gss342 pump same as what TD sells but guaranteed pefi is sourcing genuine pumps. Really nice setup and nice electrical connector at the pump. I have not had any issues with their setup either.It's a foregone conclusion that if we ask someone who sells larger pumps IF the stock pump can handle 300HP they'd all say 'no.' That said, I've been told the stock pump becomes marginal starting at about 280HP level. Certainly should not be used higher than that.
I purchased the PEFI fuel pump upgrade kit years about 4 years ago. I think he uses a 255 lph pump. When I did the calculations using stock fuel injectors at full flow, even that 255 lph pump can pump way more fuel than the injectors can flow, which means there is still a huge return to the basket keeping it full and overflowing all the time.
Some of us have added an in-line 10 micron fuel filter to our systems making certain nothing can clog up the pump or the suction socks, etc.
I've also had my injectors ultrasonically cleaned and flowed to make sure they're at 100%.
So far, no issues with my PEFI pump and fuel filter. Also, good idea to run the pump directly off battery using the Boost Kinetics relay accessory.
PEFI also has larger tank suction screens if you want. Don't know whose pump they use. Kit is expensive but it's a really nice quality kit.
BTW- no, I don't work for PEFI but their hardware is the best around IMHO.
But if the pump won't keep running right, no one's pump is any good. JM2C
Fleecer
- Jun 13, 2014
- 2019 SRX
Turboflash
- Mar 18, 2019
- Southern MN
Does anyone where to buy a new fuel filter like the factory one that attaches to the pump?
Found these on Amazon. Cheap enough I guess. Anyone ever try them?
PEFI FUEL FILTER 998T
Here is the solution to replace the OEM fuel filter on your 998 fuel pump and both filters on the fuel pump pick up Y tube. Fuel pump filter fits OEM fuel pump and our PEFI Fuel kit upgrade. Comes with everything you need for easy installation. Pump filter : Includes fuel pump filter only Pick...
precisionefi.com
Fleecer
- Jun 13, 2014
- 2019 SRX
Thanks TF!!![]()
Here is the solution to replace the OEM fuel filter on your 998 fuel pump and both filters on the fuel pump pick up Y tube. Fuel pump filter fits OEM fuel pump and our PEFI Fuel kit upgrade. Comes with everything you need for easy installation. Pump filter : Includes fuel pump filter only Pick...precisionefi.com
Turboflash
- Mar 18, 2019
- Southern MN
YW! Not bad for $22! Get all 3.Thanks TF!!
Slow998
- Jan 11, 2021
- Maine
- 2021 Thundercat
- Maine
Just get the pump filter for $22. $90 for all 3.
Turboflash
- Mar 18, 2019
- Southern MN
Understand. Did not pick that up. Thanks.Just get the pump filter for $22. $90 for all 3.
I am into post season maintenance now on my SW and I have the fuel pump removed to inspect and replace the the crows feet and pump filter socks. Although all the filters look pretty good, I am going to install all new socks like the sled came with but I am really wondering if the pump sock is necessary as the pumps sits in its own isolated banana reservoir and the fuel that supplies the pump has already come through the crows feet filters.
I have never liked the way the pump filter has to do a 90 turn right over the pump intake and eliminating the pump filter would ensure there are no restrictions to the pump inlet although it does seem to work the way the stock setup is though.
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
Just get that sock with the 90 fitting from Orilley auto that Turboflash recommended It works greatI am into post season maintenance now on my SW and I have the fuel pump removed to inspect and replace the the crows feet and pump filter socks. Although all the filters look pretty good, I am going to install all new socks like the sled came with but I am really wondering if the pump sock is necessary as the pumps sits in its own isolated banana reservoir and the fuel that supplies the pump has already come through the crows feet filters.
Part Number.....?.....Source?Just get that sock with the 90 fitting from Orilley auto that Turboflash recommended It works great
Some of the fuel pumps have a ID wrap on the pump...should the wrap be removed?
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
Turboflash
- Mar 18, 2019
- Southern MN
PEFI also has a full set of "filters".
precisionefi.com
precisionefi.com
