pedros83
- Nov 19, 2015
- Blackstock, ON
- 2010 Nytro XTX
Hi was wondering if anyone has the noise reducer installed on their hindle pipe. I am using a turnout and want to make sure it works with it. Does the reducer stick out past the outside of the muffler?
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Few days ago I ordered one from Dave, I don’t think it sticks out past the pipe.
I think without the dB reducer I would get into trouble in central Ontario lol.
mp5
- Feb 14, 2011
- New Brunswick, Canada
- 09 Nytro XTX
How much was the reducer bud? Does it simply slide in and bolt on?
WinderFab
- Mar 1, 2009
- Woodbridge, ON
$60 US shipped,
I’ve seen pics of the reducer installed and it looks to be flush with the exhaust.
I still waiting for a response on how it installs lol..
pedros83
- Nov 19, 2015
- Blackstock, ON
- 2010 Nytro XTX
shadow44
It installs for the back of the muffler and just slides in. It does not stick out and is not noticeable visibly. If ever you want to remove it, just take a broom handle and push it in from the tip and punch it out
WinderFab
- Mar 1, 2009
- Woodbridge, ON
Thanks pedros, have you fired up your sled yet?
Install sheet says to insert from the inlet part of the muffler and push it through till the end of the screen on the outlet side,
So I guess it doesn’t matter if you install it from the back?
pedros83
- Nov 19, 2015
- Blackstock, ON
- 2010 Nytro XTX
Yes i have, i think i need the db reducer. Didnt think i need to take muffler off to install. Bummer
WinderFab
- Mar 1, 2009
- Woodbridge, ON
I hear you pedros it has that bite to it when you hit the throttle which trail patrol doesn’t like lol..
Well that’s what the instructions says if I understood them right lol,
I’ll take shadow44 word that it installs from the rear...
pedros83
- Nov 19, 2015
- Blackstock, ON
- 2010 Nytro XTX
Fabio, going to order from hindle as they are close to me. Is it the 2" version i need? It has the option to select 2.25"online. Im pretty sure its 2".
WinderFab
- Mar 1, 2009
- Woodbridge, ON
Pedros I ordered it through hurricane and it doesn’t say what size it is but the slip on outlet is a hair under 2” so it should be the 2”.
- 16K
