hartattack
I have a holtzman kit on my apex gt. I bought the kit used and it came with a 2.5 ice nitrous system bottle. How do i know what way this bottle has to be mounted? I had it mounted with the valve up this weekend and pushed the button for the first time for about 2 seconds. I was watching my a/f guage and it took a second but went from 12.4 to 11.8. It did not increase rpm and i didnt feel any speed increase. I only held it for 2 or so seconds but i should notice something correct? When the sled is running in my garage at idle i tap the button and it does increase rpm so it must be working some what. Any ideas? I was thinking it might be that the bottle might have to be upside down like my boondocker kit
hartattack
Thats how mine is
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
The first 2 seconds it probably sprayed FUEL....as it will take a second to clear out the nitrous line of air!
86blackt
Open the valve with the bottle not hooked up. If you get liquid spray upright it has a syphon tube in it. If not, turn the bottle over and see if you get spray
culvert
So if you have the siphon tube, which way do you mount the bottle? Up or down?
86blackt
up should be liquid, it will have a tube in it that takes the liquid from the bottom. Standard, the liquid will come out when it is upside down
87gtNOS
- Nov 30, 2005
- Toronto
86blackt said:up should be liquid, it will have a tube in it that takes the liquid from the bottom. Standard, the liquid will come out when it is upside down
If it has a tube...it should be mounted as mine is...
Generally, the tube has a bend at the bottom, pointing towards the outlet.
helmic
- Nov 10, 2008
- Bathurst N.B. CANADA
- 2014 Apex SE STUDED,PC5,D&D Performance Exhaust,MAX-REV intakes,D&D BullsEyes,Ulmer clutch kit.Yurbo coming soon!!!
hartattack said:I have a holtzman kit on my apex gt. I bought the kit used and it came with a 2.5 ice nitrous system bottle. How do i know what way this bottle has to be mounted? I had it mounted with the valve up this weekend and pushed the button for the first time for about 2 seconds. I was watching my a/f guage and it took a second but went from 12.4 to 11.8. It did not increase rpm and i didnt feel any speed increase. I only held it for 2 or so seconds but i should notice something correct? When the sled is running in my garage at idle i tap the button and it does increase rpm so it must be working some what. Any ideas? I was thinking it might be that the bottle might have to be upside down like my boondocker kit
Dont spry at idle it is meant to work at WOT.You could cause some damage.
