sab2022
- Feb 21, 2020
- Maine
- 2023 Sidewinder S-TX GT
Yup, That's how you also fill hydraulic systems like brakes & gear boxes... bottom up. They sell hand pumps that fit quart bottles.I always use a full syringe, open the blender on the caliper and force the brake fluid in from the bottom. It forces the air out every time.
Lineman735
- Mar 3, 2013
- Cape Breton, Nova Scotia
- 2016 Viper XTX LE
2010 Nytro XTX
This may not apply in your case - but you may have air up high in the system by the lever.
You may want to crack that line and the handle bar - same procedure - pump handle, then hold - and crack bolt and quickly tighten.
Then work your way down to the lower bleeder.
I went in circles 2 yrs ago with the system not priming and it was aiYouay up high.
MS
Your
I went in circles 2 yrs ago with the system not priming and it was air way up high.
MS
Lineman735
- Mar 3, 2013
- 2016 Viper XTX LE
2010 Nytro XTX
Thanks to the advice on here i got it working, I pumped it a few times and opened the bolt by the reservoir and after 3 cycles it was firm, couple more bleeds on the caliper bleeder and it was great, appreciate the help!
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Good to hear.. Once you get it a few times and your successful the next time is easier yet..Thanks to the advice on here i got it working, I pumped it a few times and opened the bolt by the reservoir and after 3 cycles it was firm, couple more bleeds on the caliper bleeder and it was great, appreciate the help!
