Hooking up a CSS unit from Impact Global Indrustries
Bullet69
North Branch, Mn
Wondering if you can help? I received my CSS unit today and read a post that said to splice into the Blue & White wire under the handlebar cover, Which I did and grounded it to the frame. At an idle everything works perfectly. The Green, Amber, And flashing amber. When I rev it up, The flashing speeds up faster & faster until it looks like a car with a bad flasher, But the other two still work fine. I'm not an electrician, So any help would be GREATLY APPRECIATED! Also, I don't know if it makes a differance, But it is on a 2005 RX-1. Thanks
CSS
Bullet, The newer yamaha's produce almost 16 volts when the sled is running which will cause the hazard mode to flash very fast when the sled is running. We will soon have a power cord that will adjust the running voltage traveling into the CSS and allow the hazard mode to flash twice per second. The cord will be available in about month. Send us an email at contact@impactglobalindustries.com and we will ship you one at no charge. Be sure to include your name and address ;)!
