Nick1945
Really looks good
swmichvector
- Jan 27, 2009
- Clare, Michigan
- 2011 NYTRO
a liquid filled gauge will take care of that.RIGIDONE said:just a helpful hint, i ran an analog temp gauge last year switched to a digital this year.... the needle jiggles alot, i could only get an accurate reading when i was stopped.... your install looks very nice..
Where did you guys get the temp sender housing for mounting in the hose??? thx
Snowmobileaddict
There are a lots of places to get them once you confirm the thread size for your particular gauge kit.
Ulmer Racing sells an inline sender adapter that fit my sender (1/8" NPT) however, it did not lend itself well to may gauge application. In my setup, I have a single wire sender that requries the adapter housing to be grounded. I found a wide selection of sender adapters with built in grounding posts on Fleabay.
The sender adapter that Ulmer sells works great with a 2-wire sender. If I had used it in my application I would have had to clamp a grounding lead to the adapter somehow.
If you end up shopping for one, buy one that has fits 26mm or 1-inch ID heater hose.
Super Sled
- Feb 25, 2009
- Summit X
Nice write up snowmobile addict. The guage looks great! Say, what size sending unit adapter did you purchase?
Oh never mind -- see above now 1 inch or 26 mm hose. Nice write up, thx!!!!
Jonesynl
- Nov 6, 2014
- Roberts Arm, Newfoundland, Canada
- 2008 Apex MTX SE
I have a 28mm sender hope it fits :/
Dirtbikekid1998
- Mar 3, 2013
- Maine
- 2014 Yamaha Viper LTX SE Hurricane 190hp Turbo.
Jonesynl
- Nov 6, 2014
- 2008 Apex MTX SE
That's beautiful
