MNicefisher
I'm looking at getting a inline hose heater but want to make sure I get the right one will the yamaha sma-heatr-cl-nt work on the phazer and VL? It says 1" id coolant line.
Ruggybuggy
- Sep 1, 2013
- Kenora, NWOnt, Canada
- 2007 Phazer FX 144
Why don't you use a small automotive style pan heater? They are a available in different sizes and easier to install.
MNicefisher
Pan heater and warm the oil? I thought about that, but when my sled wouldn't start it was turning over nice and fast. I have battery tender on it, so stiff oil wasn't an issue. I want to heat the whole motor.
Cubby
- Dec 14, 2009
- South of Winnipeg, Manitoba CANADA
- 2015 Ski Doo 900 ACE Renegade Adrenaline
2007 Yamaha Phazer GT
The coolant hose is 25mm ID - I installed a water temp gauge from Ulmer Racing and that is what the T adapter is.
Ruggybuggy
- Sep 1, 2013
Ruggybuggy said:Why don't you use a small automotive style pan heater? They are a available in different sizes and easier to install.
I don't think a inline heater is going to help in your situation. What heat is your sled? May need the cold start update. If it cranks over quickly an inline heater isn't going to make it start any better.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
He already has it. 25mm is 0.984252 inch so it should work.
MNicefisher
Thanks. I ended up ordering yamaha part # sma-heatr-cl-nt anyone got any good info on the best location for it? Do I have to worry about bleeding the lines after the install?
Like Mooseman said I do have the cold start update but still couldn't get it to go at -29F the other day. I do have new synthetic oil with proper weight, new plugs, good batter, battery tender, and fresh 91 octane non ethanol gas and sled run great once it's started. I'm just looking for every advantage I can get. If this doesn't start it and from what I've read on here it will, I will add an oil heater too. It did start right up the other day at -20F but when we leave the cabin in the morning to head out to fish Lake of the Woods it can easily start out at -25 to -30 and my sleds got to start or my buddy will quit inviting me or tell me to buy a 2 stroke or worse yet make me ride two up on his Arctic Cat!
