Hot wire
SnowBandit
Maine
Website
www.slednewengland.com
2009 Nytro xtx
I am looking for a wire that is only hot when the sled is running.. Anyone know of one? I want to run relay off the battery to run all my add ones, and use the hot wire to trip the relay.
Under the LH side of the steering column hoop is a white plug made just for that purpose and it is switched. For me, I will try not to wire into a circuit that is used for a major function like headlight, ignition FI or what ever. Putting much of an extra load on these circuits, and you blow a fuse could leave you stranded. That accessory plug has its own fuse if I remember correctly (2 or 5 amps?) Any heavy load (heated vest or the like) should go straight to the battery with an inline fuse of course.
