freeflow90
- Jul 29, 2011
Went to start my sled yesterday and it wouldnt. i noticed gas leaking everywhere out of the carbs. I pulled the carbs off tonight and turns out one of the carb heaters broke off.I went online to see what the price was and noticed there are like 6 different options. ER MT etc...
this is my sled.. 03
the leak!
the leak!
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
The Vin number will till you what it is. But if its for a RX-1 it will all be the same.
theCATman
Well it's not an MT (mountain)
Does it have reverse? If so, it's an RX-1 ER. If not, it's a plain RX-1.
As APEX06 said, the carb parts will be the same regardless of what model.
yox185
While you have them off take them apart and clean. I bet the leak is from a stuck float valve.
freeflow90
- Jul 29, 2011
Yes it has reverse so its a ER cool. I am going to clean them and I will check those floats for sure! thanks for the help
Smokum
- Jan 31, 2011
- Prairie du Sac WI
- 2011 Apex XTX, 2003 RX-1 MTN
Anybody have a write up for cleaning the carbs? I've done it on many other older sleds, but never on a 4 stroke or Yamaha. Any help would be appreciated.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
Done the same way.
Super Sled
- Feb 25, 2009
- Summit X
This should get you started:
http://www.totallyamaha.net/forums/show ... hp?t=43118
http://www.totallyamaha.com/snowmobiles ... _carbs.htm
http://www.totallyamaha.net/forums/show ... ge=1&pp=10
To see the pics you'll have to get an acct started on the 2 stroke side -- the original Totallyamaha. Lots of Yamaha carb information over there.
