yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
I must be blind. But not seeing how to release brake side handle bar control unit so I can rotate. my goal is to rotate the control slightly- brake lever slightly lower to help me mount hand guards
Thanks if you can tell me what to look for and loosen. Thanks.
Yamadoo
Yamadoo
rlbock
Brake lever position
If memory serves me you have to remove the plastic cover which houses the light high/low beam switch, remove two Phillips screws, then you need to loosen the Allen head bolts which keep the lever tight to the bar.
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
X2 that is right.,
yamadoo
- Jun 3, 2003
Thanks no wonder I can't just "see it"
Thanks again
Thanks again
