unpride
I know these Nytros are supposed to rev out at 9100 but for some reason mine wont. Can see about 9000 then it like to go down to 8900 is there a way to fix this?
NB-NYTRO
You really don't want it to rev that high. It works best clutched at 8,700-8,800, with and 8,000rpm hole shot.
unpride
if thats the case its right on I just wish it could pull for a little longer.
My Nytro would pull 9100+ rpms when new, now that I've got 700 miles on it- I can only get 8800. WTF - I thought they got faster as they broke in? Could my spring be getting weak?
parkindale
If you guys do anymods It's nearly imposible without a dyno sheet ,without it your just guessing on were the sled makes it's hpNB-NYTRO said:You really don't want it to rev that high. It works best clutched at 8,700-8,800, with and 8,000rpm hole shot.
NB-NYTRO
parkindale said:If you guys do anymods It's nearly imposible without a dyno sheet ,without it your just guessing on were the sled makes it's hpNB-NYTRO said:You really don't want it to rev that high. It works best clutched at 8,700-8,800, with and 8,000rpm hole shot.![]()
but based on the stocks sleds that were dyno'd the numbers I posted should work well.
NyTrOMaNIaC
Actually, the stock ones that were hitting over 9000 rpms had more power than the ones at 8800 rpms according to the dyno reports I've seen on here.
yukon yamaha
- Jan 30, 2008
- WHITEHORSE, YUKON CANADA
- 2008 nytro custom! 2014 viper custom
just change your clutching.... i have been using a shock wave helix and it allows you to change your rpm with just a twist of a dial it is pritty cool
NB-NYTRO
Regardless of the HP the motor makes... is the motor not designed to make peak HP at 8,600-8,800rpms?
Kråkan
no, the peak tourque is at much lower rpms. 5800 or something like that. Peak horsepower is at 8600-8800.
