how do you remove the boot to adjust tie rod
yamamarc
Massey Ontario
Canada
2019 zr9000 Ltd
Hey guys is there a easy way to remove the boot to get to the inner locking nut or do I need to remove the hood and get it from the inside. I tried prying out the black push rivets but I stopped cause I didn't want to rip the boot
Marc
Take a pare or pliers and only pull on the little center pin. That pin should pull out and then the boot will come off. they are only just little plastic push pins.
okay thanks a million trying to adjust before heading out for a rip
just be careful when pulling them out they like to go flying if u pull to fast
You will need a crow foot socket to get up in there to loosen nut once boots pulled back , I was able to use a plumbers tool, like you would use to loosen faucet nuts. First loosen outboard nuts then go after inboard ones. RH/ LH threads. I didn't have crow foot sockets ....( do now LOL ) ;)!
Got it thanks again guys for the fast reply!!!!!
You guys rock!!!:Rockon:
Quick question, I am going to be installing my curve skis sometime this week and I assume I will have to adjust the toe out. Can I just adjust the end of the ball joint on the spindle, or is it best to adjust the inner end of the tie rod.
you will have to loosen the lock nut at both ends to adjust the tie rod if that is what you mean!
